SS-V: 6040 Simply Supported Thin Square Plate - Random Forced Vibration Response
Test No. VD05 View random response of a simply supported square plate subjected to uniform forced vibration.
Definition
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
- Value
- Modulus of Elasticity
- 2.e+11 Pa
- Poisson's Ratio
- 0.3
- Density
- 8.e+3 kg/m3
Results
PSD Y-displacement,
mm2/Hz |
PSD Surface Stress X,
MPa2/Hz |
2081 | 1028.2 | SimSolid, 3D Solid model |
2063.2 | 1025.44 | Reference, thin plate model |
